Eval crashes on selecting a Style, Style not applied. Does not work so far. Help?
Hi all
Just picked up the eval on Windows 10 [Version 6.3.19043]. Installed, select a Style and each time it does this. Tried several different ones. Obviously no feedback on the product itself, as it doesn't work so far. Some help be lovely :) Eventviewer record below
Faulting application name: CurtainsConfig.exe, version: 1.1.9.1, time stamp: 0x617be345
Faulting module name: CurtainsConfig.exe, version: 1.1.9.1, time stamp: 0x617be345
Exception code: 0xc0000409
Fault offset: 0x001dc405
Faulting process id: 0x3c4
Faulting application start time: 0x01d83eb8bd6b4440
Faulting application path: C:\Program Files (x86)\Stardock\Curtains\CurtainsConfig.exe
Faulting module path: C:\Program Files (x86)\Stardock\Curtains\CurtainsConfig.exe
Report Id: 5418390e-cca5-49d0-9bb9-f1e79355f48e
Faulting package full name:
Faulting package-relative application ID:
8,363 views 7 replies
Sorry to hear you are having issues. Can you post your full Windows 10 version number as stated on Windows "Winver.exe"
First , Please try purge and reinstall steps as mentioned here: [link]. Just make sure to redownload the latest version from your account. Reboot after the purged. Reinstall, and Reboot again after the installation. Retest it. Report back here.
I will. For sure, it's the latest version; I downloaded it, installed five minutes later, it crashed and here we are :)
OK, that does seem to have fixed it, thank you very much :)
Maybe the install needs to call a reboot at the end, as that's the only real difference from the initial installation?
Quoting hugh2, reply 5
End of hugh2's quote
I think it's supposed to prompt a restart, and that is good thing to do after any installation really, even though not always required. Great you got it working then.
:thumbsup:
It didn't for me, might be worth checking the install script. Thanks again :)
