Problem using wb5 with Panda
WindowBlinds 5.0 System Information Report:
STATUS : WB+ SRV+ HLP+ UI+ TRAY+
WindowBlinds is installed correctly on this PC.
You have one monitor in total.
(Plug and Play Monitor) 1 is attached to NVIDIA GeForce FX 5500
Wblind.dll 2005/12/20 22:41:38
Wbsrv.dll 2005/12/20 22:57:44
Wbconfig.exe 2005/12/05 18:42:52
Wbload.exe 2005/12/21 00:04:40
Wbhelp.dll 2004/09/18 16:37:00
Wbui.dll 2005/12/06 21:29:06
Tray.dll 2005/11/02 13:28:26
I'm a new user, so here goes.
I am using wb5, and every time I shut down then restart my computer with wb5 active, my taskbar around Start button icons and quick launch go black and blue!" But if I open up wb5 and switch my theme to classic style first, then I can choose any theme I want and then it loads just fine! Please Help
1,634 views 5 replies
lepew1  ...others have reported the same issue with Panda.  I'm not sure if it has been resolved as yet, but I'm sure 'Mister Windowblinds' [Neil] himself will see this and respond....
This user uses Panda Titanium. Wife uses WB5 w/ Panda with no problem https://www.wincustomize.com/Forums.aspx?ForumID=187&AID=96454
I don't know if this has anything to do with this problem, but on my wife's computer with wb5 and Panda 2005. Everything works great. Maybe it's the 2005 versus 2006???
