Recycle Bin - Empty Recycle Bin right click menu - Where is it?
I've just made my own recycle bin for DesktopX but when I right click on it the option "Empty Recycle Bin" is not there. I have to left click on the icon to show the contents of the bin and delete them manually. Is there anyway to add this option when I right click on the recycle bin? If so, how do you do it?
2,129 views 1 replies
You are probably working in development mode (DesktopX builder), in this mode the default right click menu (if such exits, like in the case of recycle bin) is overridden by the dekstopx context menu.
Unload dekstopx builder and load the object by itself. Before that though make sure that the builder isn't the default environment for dxobjects, for that go to desktopx builder preferences and make sure that the 2nd checkbox is unchecked.
