* * * * Please Help, Reinstalled and Need Help! * * * *
Hi,
I reinstalled SDC after a clean system install and Now I can not figure out how to get SDC to reconize me and my SDC Code.
WOuld someone be so kind as to give me a Step By Step of how to Log On and Give the needed info?
I can get to accept my GalCiv Number but it does not show any DL for GalCiv at all. It does not reconize my User Name and Password, but I can not find a place to give it either. :(
Please Help
Toothy
91 views 1 replies
1. Start SDC
2. In the lower right corner are the words "Registration Info"...click on the words.
3. You should now see a tabbed window with blanks for all the registration info.
4. You need to enter your GalCiv serial number and all other requested info on the Drengin.net tab. Make sure the dropdown holds the correct info for the type of serial number you have (Drengin or GalCiv).
5. On the Wincustomize tab you have to enter the name and e-mail address you used to create the Wincustomize account.
6. Go up to the menu bar. Click Tools then Edit Stardock.net account.
7. Enter the username and password you used to create your Stardock.net account.
8. Restart SDC.
You should now be done.
