Edge installed applications show blank icon on taskbar
I'm fond of using the 'install this site as an app' functionality in Edge (and presumably Chrome!) When I do so, the icon on the taskbar usually appears when I launch the web-app, but as soon as I interact with the window in any way, the icon goes blank on the taskbar. This does not happen when i disable Start11s enhanced taskbar, and has been a problem for as long as I can remember using Start11. Problem exists in Start11v2 as well.
 on launch
 on clicking anywhere in the window.
That's pinning Microsoft Loop - same when I pin Snapchat, Microsoft Planner, Pocket, anything.
41,312 views 26 replies
Sorry to hear you are having issues. I have some of these web apps on my taskbar, but they do not get blank for me. Need to know more details on your issue.
  1. Windows full version number. Use Winver.exe
  2. Start11 v2 full version number.
  3. Taskbar size, taskbar location top or bottom, taskbar auto hide or not etc.
  4. Post a video of the issue would help us understand your issue better.
Thanks for the prompt reply. I'm using Windows 11 22H2. Start11v2 v2.03 but as I say the problem has existed ever since the original Start11. I'm also running Groupy. Task bar is medium, bottom, no autohide (in fact, I've changed very little of Start11's settings from default!)
I'll take a video shortly and post!
Actually we need your full Windows version number. Something like this: Version 22H2 (OS Build 19045.3693)<- Please use Windows own Winver.exe to get that number.
I had posted about this two weeks ago was hoping to see a fix in these new versions but nothing. It's not just edge it's chrome installed apps too. This is not a one off case. This actually has been happening for me ever since enhanced taskbar was implemented.   I just didn't use enhanced taskbar. But with v2 I would like to use it because it has more features.
https://forums.stardock.com/523950/page/1/#3909670
Definitely - can other people confirm what happens for them with pinned Edge/Chrome apps when Enhanced taskbar is on? Happened for me since  Windows 10 with orig Start 11 - let alone current Win 11 with start11v2.
Just to make sure we are on the same version. I am on Edge Version 119.0.2151.72 and Windows 11 v 23H2 (OS Build 22631.2715).
Do know that when I tested on my system The app icon did change to black square for a short moment and it change back to its original icon after that. I tested on Youtube and another local shoping page. Please share a page that you see an issue so I can verify it on my system.
Added note: I am also on Start11 Enhanced taskbar.
Quoting basj, reply 7
End of basj's quote
max, apple tv, the roku channel, disney +
It's not just Edge in chrome it just displays a generic chrome icon. It's not displaying the installed Web app icon for any. Although youtube tv displays the edge blank square behaviour in chrome. It's truly all over the board. The only one I have seen work as you described is Peacock it loads very slow but finally loads the icon in edge. This is not ideal and is not working in my opinion.
Please see my post from two weeks ago for a screenshots. As someone who uses a lot of these installed apps with these browsers.  This makes this enhanced taskbar completely unusable you can't at a glance what apps are running.
119.0.2151.72 edge
22621.2715 windows
Again enhanced taskbar has always exhibited this behavior for me since the inception of the feature.  start11 v1 and v2 both did this for me.
I make a short video to show you how it look on my system. Do tell me if you are using different setting and post a video so we can understand the issue better and try to reproduce the issue.
What would be helpful basj is if for the pages you open you clicked wihin the windows. On mine the icon usually appears when you open the web app, but disappears as soon as you start interacting with it. I am getting the issue consistently with web.snapchat.com. I'm getting it intermittently with getpocket.com - sometimes the app appears, sometimes it doesn't, it ALWAYS disappears when i click to read an article. I was wondering if this was something to do with the underlying URL string changing when we click on stuff and that somehow causing icon issues.
I've made an vid showing Pocket where the icon never appears and Snapchat where it appears on load and then disppears when I click into a conversation - please excuse the blurry bit where I'm censoring my conversation list. At that point I'm just clicking on a conversation to open it.
Thank you for the video, that explain something to me. I noticed your setup is different than mine. On mine, I pinned those web apps to taskbar and launch it from there. But if I un-pin it from taskbar and launch those app via start panel, as you did, I do get the blank icons on taskbar as shown in my screenshot below.
I have forward your problem to Stardock Support Team for their assistance. Please keep an eye on this thread for any updates. We appreciate your feedback and patience.
Great spot. I had missed the context that you were using taskbar pinning! I can confirm that when I pin all the sites to taskbar, the icons behave themselves just fine - it's launching from Start menu alone that's causing the problem.
And for what it's worth, I'm certain the problem also affected Start10 in a similar way.
Quoting basj, reply 11
End of basj's quote
Stated in my original post. Unpin to recreate all these issue.
This video shows the chaos that is edge apps and enhanced taskbar. Also shows Chrome apps displaying just the generic chrome icon.
I have logged this to have it looked at.
Internal ref: ODNT-7441
Thanks for the report.
Quoting IanMoyes, reply 13
End of IanMoyes's quote
It is somewhat unlikely this impacted Start10 or Windows 10 in any way as it would need the enhanced taskbar to be in use which is a Start11 Win11 exclusive thing.
Does this problem continue if you set Start11 to not combine taskbar buttons and ensure it is set to show captions?
The issue still persists for me regardless of taskbar display setting. Slow loading every time you open and close the app of icon. Sometimes the icon just never appears. Other times when clicking through the windows the app will just stop displaying the icon.
Quoting Neil, reply 17
End of Neil's quote
This does appear to solve the problem for me - the icon remains on both Pocket and Snapchat as I browse about.
Quoting lazyboyy, reply 20
getpocket.com
End of lazyboyy's quote
It is strange the issue continues for you when it was resolved for others but your issue also seems different as it seems to impact all modes but the issue didn't for others.  This is pointing to a different cause.
Also did you uninstall, reboot and then install the newer beta just to be sure all files were replaced?
Quoting Neil, reply 21
Quoting lazyboyy,
getpocket.com
End of Neil's quote
I just did what you suggested. The edge icons are still loading very slowly on average three to 10 seconds. Then they sometimes just randomly disappear and don't come back. Interestingly enough it's not just edge and chrome maps that are disappearing it is also windows metro apps.  I haven't seen the blank blue icons though.
Quoting lazyboyy, reply 22
Quoting Neil Banfield,
Quoting lazyboyy,
getpocket.com
Are those metro apps showing an icon initially and then losing them later?
Are they pinned or unpinned?
Quoting Neil, reply 23
Quoting lazyboyy,
Quoting lazyboyy,
getpocket.com
End of Neil's quote
It's a metro app that's pined. It's show initially and then disappear around the same time I'm using the edge apps that are disappearing/loading slow. I don't think they're connected though because I have had this pinned metro app (mytube for windows store) disappear randomly since enhanced taskbar the introduced in v1.
On Start11 v2.05 now and it appears to have significantly improved. I'm now seeing the icon consistently on Pocket, Microsoft Loop and Snapchat, without having to pin the icon to the taskbar - fabulous!
I am noticing that any time I click on these web apps to do something: e.g. open an article in Pocket, or a chat thread in Snapchat, the icon on the taskbar briefly flickers - it looks to me like a refresh is happening in line as it goes to a different URL or something? If that's what's happening, ideally the icon would only need to be refreshed if it was actually changing, but don't get me wrong: this is still a massive improvement on the blank space!
Can anyone else confirm that this is working for them on 2.05?
