Priceless Parts in Beta 3
Curious what is out there.  Though mostly I'm curious about this "Enrage Sword" - is it really just a lackluster sword, or is there something that doesn't have a text description?
Gutpunch Gun (pistol) 21 dps, 30% 4x crit, 20% knockback 60
Brawler Fist 28dps, +100 hp
Big Boom Pod (volley pod): sc3 *only*, 60 damage, 10 area, 10 attacks, cooldown 60.
17,555 views 14 replies
Hmm, I could believe that Enrage Sword is missing some text. Gives you a short damage buff to that Servo. Amount depends on which level it is, etc.
Quoting BXP_Godgib, reply 1
End of BXP_Godgib's quote
What is a "short" damage buff?
Heavy Hitter: (fist) 17 dps (in shop) Power boost (Sc2+) servo 3x damage for 5 sec, cooldown 60
Gladiator Upgrade Package (cpu, I think) pistols +3, swords +3
Quoting wondible, reply 2
Quoting BXP_Godgib,
End of wondible's quote
Not at my laptop, but I think it's 2x damage for 4 seconds. Useful when combo'd at the right time. Should pop the same "I'm buffed" FX as Unstable Core, so your enemy will know what's going on.
Quoting BXP_Godgib, reply 6
What condition activates it?
Quoting wondible, reply 7
Quoting BXP_Godgib,
It's a command that's added to your Servo. Pop it whenever you want. 45 or 60 sec cooldown, IIRC.
Quoting BXP_Godgib, reply 8
Not this one. Generator must have rolled a tails on the ability.
p.s I got also got an epic "Triple shot missile pod" that has an sc3 200 missile, listed as a single shot - worse in every way then the lower rarety one, and with an incorrect name.
Quoting wondible, reply 9
Quoting BXP_Godgib,
Hmm, sword's working here (need to go check Beta3 build).
I see the bug on the missile pod. Fixed! (next build)
http://i.imgur.com/WOraOoG.jpg this is really cool, 2 of these would be really sick, a little like the gutpunch pistol but has +2 pistol range per s.con, and trample!
Really digging priceless parts this update, BXP. There are some very interesting parts with lots of weird mods on them. This sort of thing goes a long way to getting that diablo loot feel going. It isn't just about bigger numbers, these sort of parts open up entire new builds for the servo. As interesting if not more so  than ability items.
Quoting Dracohouston, reply 13
End of Dracohouston's quote
Great to hear!
