rickdorsey rickdorsey
Edge and Task View missing from taskbar when Start10 running
Running the release version of Windows 10.  When Start10 is running, once any application is run, the Edge and Task View icons disappear from the task bar.
56,244 views 67 replies
Reply #51 Top
There was some confusion over this issue initially as there was a related problem which we fixed for 1.0, but this one has been reproduced now and resolved having understood what was happening.
I hope we can put out the update next week.
Reply #52 Top
i too have the same issues, auto hiding the taskbar makes edge icon and 2 of my quick start icons vanish
also i have another problem - when i bring up the start menu the right hand side of the menu is 100% transparent instead of being solid blue, happens everytime i launch Windows 10, only way to sort it is to go into setting and reset the back ground! this also need fixing!
Reply #53 Top
Quoting borgdronex1, reply 52
End of borgdronex1's quote
Could you post a screenshot of this please.
Reply #54 Top
ive since changed the start menu look from shadow to rounded windows 7 but im still getting similar problem - 1st pic is how it should look, 2nd pic is how it looks when 1st booting into windows
http://s1379.photobucket.com/user/BorgX666/media/SM1_zpszbrrxtlu.jpg.html]
http://s1379.photobucket.com/user/BorgX666/media/SM2_zpsptylmira.jpg.html]
Reply #55 Top
I have reproduced this.  It seems limited to custom themes only.
Thanks for letting us know.
Reply #57 Top
Quoting thurmanlowder, reply 49
I'm using ver. 1.0 and am having the same problem with the Edge icon disappearing when I install Start 10.  When I uninstall Start 10 the Edge Icon reappears.
End of thurmanlowder's quote
I've created a ticket for you and you should receive it shortly.
Reply #58 Top
This continues to be an issue for me.. Edge and Taskview icons disappearing. Windows 10 64 bit pro (clean install).  Is there a newer version of Start10 available above 1.0.0?
Reply #59 Top
Quoting kollcycle, reply 58
End of kollcycle's quote
Is your taskbar set to autohide?  If so we have fixed this internally and it will be released in the next update.  I am hoping that will go out later this week.
Reply #61 Top
The beta 1.01 is out and should address this issue.  It is on the downloads page for customers.
Reply #63 Top
Quoting LesserHellspawn, reply 62
Installed it. Unfortunately the issue persists.
End of LesserHellspawn's quote
Can you go to the Start10 install folder and right click on Start10_64.dll and see what the signing date is on it please.
Reply #65 Top
Quoting LesserHellspawn, reply 64
‎Sure, it is tuesday, Aug. ‎11th 19:32:54
Looks like you still have the old version from v1.0.  I just checked mine (which fixed the bug) and the signing date of the DLL is August 20th.
Reply #67 Top
just to let you know the new beta 1.01 has solves my issues, its working fine now :)
Quoting Neil, reply 55
End of Neil's quote
Quoting borgdronex1, reply 54
Reduced 58%
Original 1024 x 576
Reduced 58%
Original 1024 x 576
