Double monitor problem
Dear All,
I have  2monitör and Intel(R) HD Graphics 3000 graphic card. With windows 8 everything was working. I have installed windows 8.1.
When I changed deskscapes wallpaper for monitor 2 and applied there is nothing. Blank screen.  I haven't solved this problem.
What is the problem?
6,742 views 3 replies
Hellol BlackHawk13
could you explain what you mean by blank?
Is the second monitor only showing a black screen?
Do you run a dynamic dream ?
IF you don't know please post the dream name... or provide some screesnhots.
Also what is the version of Deskscapes?
Did you reinstall Deskscapes after installing Windows 8.1?
If not, try that. Then, you may need to install a codec pack.
I have been using DisplayLink Usb ScreenCard. And I use it for secondary monitoring with laptop. I have found Both Intel(R) HD Graphics 3000 driver for windows8.1 and display link driver for windows 8.1 and installed... ANd My problem was solved.
I think sometimes windows 8.1 need special driver.
thanks for your help...
