Problem with windowblinds and wallpaper?
I don't know what kind of problem this is or if there's a solution but anyway, I have this wallpaper and i'ts size is little so instead of choosing to stretch it( which makes it look bad) I choose to center it and choose a background color for it, but everytime the computer restarts or just starts it chooses a different color, other than what I chose for it. It seems to go with the windowblinds skin but i'ts not the color I chose. Is there any solution or is that just the way it is? Richard
2,312 views 5 replies
Look in windowblinds config and click Basic Settings ... look for "Apply the skins color theme" and uncheck it .... the apply changes.
The desktop colour is set in SkinStudio. It's easily changed, providing you have SS..
If you have SkinStudio, open the current skin and navigate to Miscellaneous>Colours>Miscellaneous>Background-Desktop and change the colour to the one you want then click the 'apply and save skin' button on the toolbar (the WB icon).
...if you uncheck 'apply the skins colour theme' it will disable all the colours
I unchecked apply the skins colour theme and everythings allright now but why does it have recommend by it? Thanks everybody
recommended just means thats what stardock recommends you to use for the skins, it isn''t mandatory.
spelling
[Message Edited]
