Task Panel
Anyone know why the special task panel might not show up in a skin I created? All the attributes are set right and it shows up with other skins but when I load the one im working on its just not there. Any ideas? >
1,538 views 4 replies
If your talking about the large picture that shows up in the main portion of the window, then the first pixel in the upper-lefthand corner needs to be the same color as the background of the window. Only other thing I can think of is that sometimes XP get''s a little skizzy when you apply a lot of skins in succession and the task panes just stay with the default Blue LunaXP panes, by unloading Windowblinds, rebooting then restarting WindowBlinds, it usually fixes it, but I haven''t noticed that happening lately with the latest pre-release of WindowBlinds
Actually its the whole thing no bars no down menu nothing i cant figure it out. My images match the background and if i load another skin everythings there its kinda strange.
If your using the full version and making a UIS2 skin, then I don,t get why it wouldn,t show up when you apply the skin, when it shows up in skinstudio. Yes it does sound strange. Maybe somebody else might have a clue.
Its full version and it is UIS2 i even set it all back to defualt windows blue settings in my skin its still gone. It shows in any other skin though I bet its something really small and stupid im over looking
