edit vista / 7 explorer parts
listed for the graphic "search field background" the frame count is 5 however the frame order only lists 4 components. which is correct and what is missing if the frame count should be 5?
2,060 views 7 replies
Search field background has 4 frames and always has done.  I have looked in SkinStudio here and it shows as having 4.
What does the default button say on it?
Could it be that your skin has it incorrectly set to 5 for some reason?
The search field button says Default (4), but when you click it it chages the image count to 5.  Definitely a problem.  :S
ah, thank you, yes, obviously a hic-cup.
I've learned to ignore the number it says for default...I've seen two different skins of Dani's with 2 differing defaults on several things.(Not trusting that my own skin had been using the default settings)
Sometimes it appears that the number for default is just reflecting how many frames are actually in the image...but I dont see how it would know. 8| (except that maybe  its just using the state code equals)
which state. :)   interpretion, "I'm not sure what you mean" but, isn't the frame count number the number that the graphic is divided by to give the individual state sizes. I guess I can just change the number back, we'll see.
sometimes it seems that the default button just shows the image count... :S ;)
what I was seeing might have been something that has more than one set of defaults (due to something in extra settings )
I'm a little beat from debugging my skin... |-O :zzz:
