Connection Info box is always empty, and connection issues
Hi. Just got the game yesterday on the advice of a friend. We played our first game with no difficulty, which was a custom game.
That was the last time I've been able to play. Since then, I can't connect to any games, either with the same person or in general skirmish/pantheon. It always gets stuck at "connecting to other players."
The weird thing about this to me is that the "Connection Info" box is always empty for me. Totally empty. Even I don't show up in it. While my friend was trying to help me troubleshoot, he'd host a game, and even before anybody joins he'd be able to see himself in there. I can't. Same thing when joining, I don't appear to exist as far as Demigod is concerned.
Tried port forwarding, setting up the ports in ImpulseReactorOptions, going into the DMZ, disabling Windows Firewall, and combinations of those. Finally when I removed the router entirely and connected directly to the Internet, I could play again. Rest of the house is obviously unhappy with the idea of me hogging the Internet like that, though.
The router is a Linksys WRT54G. It's an older model but hasn't given me problems in a game before, and I flashed it up to the latest version. Is the router really the trouble, like it looks to be? Anybody have any suggestions on how to make it work? Barring that, anybody have suggestions on a router that *does* work?
Thanks.
edit - I don't know if this is related, but the Impulse friend chat windows also act oddly for me. If I'm chatting with a friend, I don't see any of his messages until I sent one. That is:
1. I send him a message.
2. He replies.
3. I reply.
I won't see #2 until #3 happens, no matter when he sent it. Once I reply, his message appears instantly with the correct timestamp, so it showed up a couple of minutes before actually becoming visible. Very strange. It might be unrelated to the connection problem, I'm not sure.
1,279 views 2 replies
the impulse friends is not running correctly, some people cant even see thier friend online, ive had the same problem joining i just restart my game and it works :S i dunno
Update to this. I found the log file. It's pretty huge, but here is the first bit from when I last tried to host a game. The last line I copied in (NAT_FAILED) suggests something is going wrong, but I can't tell what. Should also mention that I'm using Vista 64 bit, and the router is connected over ADSL using PPPoE in Canada. Thanks for any help!
[04-18-2009 18:56:22 089] CVP: ResetTimeToRefreshLogin
Installed version: 1.00.048
Latest version: 1.00.048 (server 1, beta 0)
[04-18-2009 18:56:28 157] CVP: ResetTimeToRefreshLogin
[04-18-2009 18:56:28 416] CVP: ResetTimeToRefreshLogin
[04-18-2009 18:56:32 946] CVP: ResetTimeToRefreshLogin
[04-18-2009 18:56:44 311] CVP: ResetTimeToRefreshLogin
[04-18-2009 18:56:51 924] CVP: CreateGame with name test Host: Tridus (player 28918)
[04-18-2009 18:56:52 103] GetAvailableConnectionsEngine starting as client
[04-18-2009 18:56:52 103] client starting with 1 socket descriptors.
[04-18-2009 18:56:52 113] Ping server cvp2.stardock.net on port 6000
[04-18-2009 18:56:52 602] Message received by GetAvailableConnectionsEngine: MP_MSG_VERSION_PONG from 209.124.63.216:6000
[04-18-2009 18:56:52 612] CMultiplayerEngine::Shutdown for GetAvailableConnectionsEngine. Send Disconnect notification: 1, Restart: 0
[04-18-2009 18:56:53 144] CVPMultiplayerEngine: NAT punchthrough is enabled.
[04-18-2009 18:56:53 144] CVPMultiplayerEngine::SetupNATPunchthrough()
[04-18-2009 18:56:53 144] CVPMultiplayerEngine: setting up NAT Punchthrough Client
[04-18-2009 18:56:53 144] CVPMultiplayerEngine: Attaching NAT Punchthrough plugin
[04-18-2009 18:56:53 144] CVPMultiplayerEngine starting as database client
[04-18-2009 18:56:53 145] client starting with 1 socket descriptors.
[04-18-2009 18:56:53 156] CVPShowConnectionMiniWindow
[04-18-2009 18:56:53 407] Message received by CVPMultiplayerEngine: MP_MSG_DATABASE_UPDATED from 209.124.63.216:6000
[04-18-2009 18:56:53 432] Database updated for TitleID 444 gameID 192958
[04-18-2009 18:56:53 568] Message received by CVPMultiplayerEngine: MP_MSG_DATABASE_UPDATED from 209.124.63.216:6000
[04-18-2009 18:56:53 568] Database updated for TitleID 444 gameID 192958
[04-18-2009 18:56:53 568] Message received by CVPMultiplayerEngine: ID_CONNECTION_REQUEST_ACCEPTED from 209.124.63.216:6000
[04-18-2009 18:56:53 568] Connected to facilitator at 209.124.63.216:6000. My External: 156.34.73.162:50871
[04-18-2009 18:56:53 571] Message received by CVPMultiplayerEngine: MP_MSG_DATABASE_UPDATED from 209.124.63.216:6000
[04-18-2009 18:56:53 571] Database updated for TitleID 444 gameID 192940
[04-18-2009 18:56:53 708] Message received by CVPMultiplayerEngine: MP_MSG_DATABASE_UPDATED from 209.124.63.216:6000
[04-18-2009 18:56:53 708] Database updated for TitleID 444 gameID 192920
[04-18-2009 18:56:53 829] Message received by CVPMultiplayerEngine: MP_MSG_DATABASE_UPDATED from 209.124.63.216:6000
[04-18-2009 18:56:53 829] Database updated for TitleID 444 gameID 192904
[04-18-2009 18:56:53 996] Message received by CVPMultiplayerEngine: MP_MSG_PLAYER_QUIT from 209.124.63.216:6000
[04-18-2009 18:56:53 996] Message received by CVPMultiplayerEngine: MP_MSG_DATABASE_UPDATED from 209.124.63.216:6000
[04-18-2009 18:56:53 996] Database updated for TitleID 444 gameID 192958
[04-18-2009 18:56:54 140] Message received by CVPMultiplayerEngine: MP_MSG_DATABASE_UPDATED from 209.124.63.216:6000
[04-18-2009 18:56:54 140] Database updated for TitleID 444 gameID 192920
[04-18-2009 18:56:54 283] Message received by CVPMultiplayerEngine: MP_MSG_DATABASE_UPDATED from 209.124.63.216:6000
[04-18-2009 18:56:54 283] Database updated for TitleID 444 gameID 192853
[04-18-2009 18:56:54 378] Message received by CVPMultiplayerEngine: MP_MSG_DATABASE_UPDATED from 209.124.63.216:6000
[04-18-2009 18:56:54 399] Database updated for TitleID 444 gameID 192936
[04-18-2009 18:56:54 560] Message received by CVPMultiplayerEngine: MP_MSG_DATABASE_UPDATED from 209.124.63.216:6000
[04-18-2009 18:56:54 560] Database updated for TitleID 444 gameID 192957
[04-18-2009 18:56:54 561] Message received by CVPMultiplayerEngine: MP_MSG_DATABASE_UPDATED from 209.124.63.216:6000
[04-18-2009 18:56:54 561] Database updated for TitleID 444 gameID 192958
[04-18-2009 18:56:54 903] Message received by CVPMultiplayerEngine: MP_MSG_DATABASE_UPDATED from 209.124.63.216:6000
[04-18-2009 18:56:54 903] Database updated for TitleID 444 gameID 192936
[04-18-2009 18:56:54 903] Database updated for TitleID 444 gameID 192958
[04-18-2009 18:56:54 903] Message received by CVPMultiplayerEngine: MP_MSG_NAT_COMPLETE from 209.124.63.216:6000
[04-18-2009 18:56:55 051] Message received by CVPMultiplayerEngine: MP_MSG_DATABASE_UPDATED from 209.124.63.216:6000
[04-18-2009 18:56:55 051] Database updated for TitleID 444 gameID 192880
[04-18-2009 18:56:55 299] Message received by CVPMultiplayerEngine: MP_MSG_DATABASE_UPDATED from 209.124.63.216:6000
[04-18-2009 18:56:55 299] Database updated for TitleID 444 gameID 192963
[04-18-2009 18:56:55 299] Message received by CVPMultiplayerEngine: MP_MSG_NAT_COMPLETE from 209.124.63.216:6000
[04-18-2009 18:56:55 299] Database updated for TitleID 444 gameID 192829
[04-18-2009 18:56:55 299] Database updated for TitleID 444 gameID 192915
[04-18-2009 18:56:55 299] Database updated for TitleID 444 gameID 192958
[04-18-2009 18:56:55 300] Message received by CVPMultiplayerEngine: MP_MSG_DATABASE_UPDATED from 209.124.63.216:6000
[04-18-2009 18:56:55 300] Database updated for TitleID 444 gameID 192880
[04-18-2009 18:56:55 300] Database updated for TitleID 444 gameID 192958
[04-18-2009 18:56:55 409] Message received by CVPMultiplayerEngine: MP_MSG_DATABASE_UPDATED from 209.124.63.216:6000
[04-18-2009 18:56:55 410] Database updated for TitleID 444 gameID 192880
[04-18-2009 18:56:55 410] Message received by CVPMultiplayerEngine: MP_MSG_DATABASE_UPDATED from 209.124.63.216:6000
[04-18-2009 18:56:55 410] Database updated for TitleID 444 gameID 192958
[04-18-2009 18:56:55 661] Message received by CVPMultiplayerEngine: MP_MSG_DATABASE_UPDATED from 209.124.63.216:6000
[04-18-2009 18:56:55 661] Database updated for TitleID 444 gameID 192915
[04-18-2009 18:56:55 661] Database updated for TitleID 444 gameID 192880
[04-18-2009 18:56:55 661] Database updated for TitleID 444 gameID 192950
[04-18-2009 18:56:56 007] Message received by CVPMultiplayerEngine: MP_MSG_DATABASE_UPDATED from 209.124.63.216:6000
[04-18-2009 18:56:56 007] Database updated for TitleID 444 gameID 192880
[04-18-2009 18:56:56 007] Message received by CVPMultiplayerEngine: MP_MSG_PLAYER_QUIT from 209.124.63.216:6000
[04-18-2009 18:56:56 126] Message received by CVPMultiplayerEngine: MP_MSG_DATABASE_UPDATED from 209.124.63.216:6000
[04-18-2009 18:56:56 126] Database updated for TitleID 444 gameID 192915
[04-18-2009 18:56:56 126] Database updated for TitleID 444 gameID 192958
[04-18-2009 18:56:56 126] Database updated for TitleID 444 gameID 192950
[04-18-2009 18:56:56 237] Message received by CVPMultiplayerEngine: MP_MSG_NAT_FAILED from 209.124.63.216:6000
