Problems with fonts...
1st problem
I see caption font like in this image
http://img405.imageshack.us/img405/5715/24055551me7.jpg
as u can see, the font looks not clean...i turned on cleartype, but the problem remains
How can i resolve?
2nd problem
How can i change font with skin studio? I go in "change skin fonts" --> select font for caption and bottons (for exemple) --> click "change font" and select new font --> click "apply"...but the font doesn't change. Why?
Thanks a lot! :D
3,899 views 5 replies
official forum and nobody can answer these? come on guys.
1. I don't remember exactly how to resolve that but I do remember having had the same problem. Play a bit with text shadow, I think it had something to do with it.
2. I have the exact same problem (opened a thread quite some time ago, no answers). My changed fonts simply aren't shown when applied. The only way I know to resolve this one is by editing the corresponding *.uis file with a text editor.
Greets,
Zetto
The forums are not meant for official support.  You need to email support@stardock.com for that.
The forums are where you can seek help from the members of the community that may have come or run across the problem you maybe having.  At times a Stardock support person may stop by and reply if the answer is quick and easy.
A non reply usually means that no one had an answer or your post was just missed by someone who could answer (happens a lot).
Cleartype \ Antialiasing does not work in per pixel frames in WB.
I have clear type and anti-alisising enabled with my fonts in both regular and per-pixel frames...and they work fine.
nickdc, are you saving the changes in skin studio?  If you don't save, your changes will not show up when you re-apply the skin.
It sounds like you are using skin studio 6...if you are, I can't tell you all the steps necessary to change fonts.  I am still using version 5, and I think things are done differently, as far as making changes.
I'll rephrase that, it doesnt work.. very well.. at all. Its been an issue for a while.
