Need help with using skins with windowblinds
Hi, i just got WindowBlinds and downloaded a few skins from the website to try them out. The problem is, everytime i try to apply a skin, instead of the skin i tried to apply, it applies the Windows Classic skin. Can anyone help me solve this? BTW im running Windows XP if that matters
17,064 views 7 replies
Open the WindowBlinds Configuration screen and click on "System info" then click the "Copy text" button. Paste that info here.
WindowBlinds version : WindowBlinds 6.0 (build 32 x86)
(Plug and Play Monitor) 1 is attached to Radeon X1300 Series
Wblind.dll 2007/09/27 12:40:19
Wbsrv.dll 2008/06/30 01:51:43
Wbconfig.exe 2007/10/01 18:09:33
Wbload.exe 2007/09/27 16:42:44
Wbhelp.dll 2007/07/11 15:06:07
Wbui.dll 2007/09/22 13:13:06
Tray.dll 2007/09/12 18:52:21
Screen.exe 2008/06/30 01:51:24
Here it is, hope someone can help me
May be a good idea to uninstall this version and reboot. Run a scanning program to ensure nothing was left behind and then either install the 'trial' version or purchase WindowBlinds.
+2 Loading…
EDIT:Forget about this las question, i figured it out. Thnx very much for the help
A restart of the computer usually fixes problems like these when I've encountered them.
:LOL:
