Will Skin Studio Pro 4.6 Help create Alpha Blended Images for Wb 5
I just bought W.B.5  AND I love all the possibilities. But I have one question. The latest build for Skin Studio is 4.6. So Will I be able to, Create the images needed for tranperency or do I have to wait for the release of Skin Studio 5.....I would love some help.
                                Thanks for the help.....
1,837 views 4 replies
You will need to wait for SkinStudio 5 to create WB 5 skins.
SkinStudio does not create the images, it puts them together, you need graphics software to create the images.
SkinStudio 5 is still in beta, I am not sure when the final release build is due out.
Hey thanks BRO.  I thinks that I did not explained myself. I have the graphics, I used PhotoShop CS2. But what I menat was that, If I will need Skin Studio 5 in order to  use alpha blended images...
Hey thanks BRO.  I thinks that I did not explained myself. I have the graphics, I used PhotoShop CS2. But what I meant was that, If I will need Skin Studio 5 in order to  use alpha blended images... And make a working WB.5 skin or Is there an option in Skin Studio 4.6 Pro that will enable me to use those images in a WB skin...
