HELP !!!!! WindowBlinds 4.6 Problem!! Skins load incorrectly !
I installed windowblinds 4.6 just yesterday and everything seemed to be working fine for a while. However, after loading a couple of skins (which worked perfectly fine), the skins started to load incorrectly. For example, i loaded the christmas theme, and all I see are red toolbars. None of the themes are showing up properly, I only see colored toolbars..someone please help
1,753 views 2 replies
Try refreshing the explorer shell:
Run Windows Task Manager, choose processes tab, highlight "explorer.exe", choose "end process", choose "file" menu, choose "add new process", type in command line: "explorer.exe". Hope this helps. Happy skinning!!
