Upgraded from Trial to Pro. I had a problem with Pro not working then fixed it.
FIX!
I just downloaded this program and it's sooooo useful. However, I had one problem. I could not use the full version! I installed it, unistalled, reinstalled, tried everything. Nothing was working! Well, what I did was hold down shift and then I could go between my computers. This is great! Now it works. What is wierd is when I went in and checked the option that requires you to hold down shift it was not checked... This option does not seem to work at all on my computer and is on no matter what.
So moral of the story is....try holding down shift key if the program does not seem to work!
Besides that one error, I found the program very easy to set up!
1,026 views 1 replies
Good for you Big T! Makes it easier to use if you read through what settings/options are available before delving full-force into a new software, huh? Good work, figuring that out.
