Please HELP! DesktopX Pro Installation problem!!
I just purchased DesktopX Pro & upon installation it wants to default install to this destination folder:
C:\ProgramFiles\Stardock\ObjectDesktop\IconX
Is this the correct directory? Wouldn't it be installed in?
C:\ProgramFiles\Stardock\ObjectDesktop\DesktopX ?
When I browse to that folder it automatically adds IconX anyway like this:
C:\ProgramFiles\Stardock\ObjectDesktop\DesktopX\IconX
So where should I install it? Also does it matter if I install it over the DesktopX in my Stardock Central or should I uninstall DesktopX in SC first? Thanks so much for any help.
3,260 views 1 replies
Greetings,
What you listed first isn't the correct directory, DesktopX should go into its own directory. Since you're moving from standard to Pro, I would recommend uninstalling the old version first, but that's simply my personal preference.
