help with right click
how do i edit the rightclick menu?i cant seem to find the edit tool of config file for it.
help please
978 views 1 replies
You should just be able to click on the RightClick.exe icon in the Stardock/Object Desktop/RightClick folder and it will open the RightClick Menu Editor. Or, if RightClick is running and you want to open the Menu Editor, right click on the desktop to show the RightClick menu, right click on the RightClick menu and left click on "Properties". Sheesh, it's easy, but that sure makes it sound confusing Um...read it slow...I think it does make sense
