I need help with LogonStudio problem...
...please advise.
Alrighty, Hello -
I am making Logons with LogonStudio and I'm having a problem. When I click on the text portion of the logonwindow (where it displays your user icon, username, and password typing bar) and I change the font, click save and apply, nothing changes. The font is still the default font. I'm wanting to change the font of "Type your password". Like, I'm making Halo Logons (which I will upload to here when i'm done :-}), so I want to use the Halo Font. I can change the other 'messages' on the logon screen, just not the "Type your password" part.
I know it can be done, b/c I've done it with my first 3 Halo logons, but I cannot seem to change that part anymore, with any logons I try. Did I deselect something?? I'm really confused.
Thx in advance.
Mythrander101
2,063 views 4 replies
try reinstalling it, then do it again (dont forget to save ur logons... ive forgotten b4, it sucked)
Try changing font for user status, just below user name in elements menu. This is just a quess as I do not use a
password.
I eventually figured it out.
The 'comments' section (right of 'turn off computer' section) also controls that "Type your password" section. so the font of 'comments' changes the font of "Type Your Password".
Thx everyone.
doesnt using non-standard fonts mean that for systems without that font,itll show up in.. godknows what? cause i doubt logonstudio (or rather, the logonui.exe) bundles the fonts used...
