Problem with My Skins...admins help please?
Ok here goes a prob i have for a long time now.It's about all sorts of numbers in My Skins!The problems listed are below as:
a.It shows i have 131 Wallpapers,whereas i can count only 88(Counted four times to make sure).
b.It shows i have 7 Screenshot,whereas i have only 4 and 1 in moderation.
c.When i'm in a page where there are no items of one kind and i give a command to re-sort based on the category of that kind i get that i have no skins at that category.(E.G.i'm at page 3 where i have no DesktopX Objects if i set it to re-sort showing only DX Objects i get that there are no items in the category,whereas if i do the same in page 1 i get the list fine)It's just a lil something i noticed and thought it would be good to mention.
d.Is there anything wrong with rating system?Just curious cause all my walls recently are rated 4(Which if it's up to me i consider it to be low when you compare it with some crappy walls of the past that got rated up to 8-9).I personally don't care about ratings,i aint trying to make a big deal out of it,it's just something i've noticed and i decided to report just to check it out.
e.I lately noticed that an AVS pack of mine for Winamp the comments on it got mixed with comments from another artist.If it's possible please clean the comments up or move them to the place they belong,i don't like credit i don't deserve.Here is a link to it:Link
Well these are the probs i'm dealing with right now,i thought i'd report them to help this site work at its best.
PS:One small request:If possible when will the totalling feature be implemented to the system?I really miss that old-site feature.
1,202 views 3 replies
I've had a look at the ratings and can't see anything out of the ordinary. That is, there's no-one person dragging down the ratings.
All the other things are site coding issues best dealt with by T-Man.
There is one other thing I can fix though. I find it amazing that someone with such a huge library is only a citizen - just sorted that
Solved 'e'....
Good catch, Fuzzy...
Thanks Jafo,you really are an embassador for all of us around here
Thanks Fuzzy,i was just curious,as for the subscription thing i'm thinking about it,but i just can't afford it right now,since i'm at university and practically i get the equivelent of money i need to just survive.Actually i'm pretty happy to own a PC and just create stuff for the community,regardless if those stuff are assumed to be of high or low quality.
