Start10 + Start11 - Click on start button problem
Start 10 1.98 on Win 10 22H2 x64, all updates.
Click on Start button -> Start10 menu appear (all OK)
Click again on Start button -> Start10 menu it's not hiding, instead is disappear and appear again. (not OK)
Also, the menu has a delay before appears.
Animation it's OFF.
If I use Ctrl + click several times the standard Win 10 menu shows and hides correctly.
I uninstall Start10 but the problem persists.
Is there any setting to do to fix this?
I uninstalled and I install Start11 1.55.
Same thing.
873 views 2 replies
Sorry to hear you are having issues. But, I can not reproduce your issue. Refer my short video below.
Also,
I suspect, this show that the issue is not from Start10. Perhaps try system scan.
Please try the following:
-For Win8/10 Users: Open the Start Screen, and type 'cmd'. Right-click on the search result and select 'Run as administrator' from below.
-Type: sfc /scannow
-Wait for the scan to complete (this can take several minutes)
Some help on how this looks should you need it:
https://support.microsoft.com/en-us/help/929833/use-the-system-file-checker-tool-to-repair-missing-or-corrupted-system
If the SFC finds errors, but cannot fix them, please also run the following command in the same command prompt window:
dism.exe /online /Cleanup-Image /RestoreHealth
https://www.windowscentral.com/how-use-dism-command-line-utility-repair-windows-10-image
The above command should assist with replacing any damaged or problematic system files. Please note, however, since it may require restoring certain files, this process can take some time and you will need to be patient until it has completed.
Please let me know whether this resolves your problem or if you have any additional questions.
errors found, SFC corrects them.
i used also DISM.
restart.
Same thing.
Maybe it's asking for an OS reinstall.
