Start11 sound when clicking Power
Hi.
When I click on the Power menu, in the Start11's menu, it makes a notification sound, even after I uninstalled WB11. Is there a way to remove that?
Here's my specs:
4,263 views 8 replies
Sorry to hear you are having issues. Not sure how is that happened. But, try this, reinstall Windowblinds turn off sound setting, refer screenshot below. If you still wish to uninstall Windowblinds, before uninstall, it is best to apply the Windows default theme, than uninstall.
I tried that and still getting the sound when I clicked the Power options in the Start11 menu.
Is there a setting in Start11 that involves sounds that I can get into? Or as a last resort, I'll have to purge Start11 and reinstall it.
May I know from which WB theme you applied that causing the sound in the first place. Might need to reproduce it on my side and see what can be done.
It's been a couple days since it happened, so I can't remember the skin name on the top of my head. Try one of your own or others with the sound option on and find out.
Another bug I noticed when using WB11 (I know this isn't the right place for it, or on topic), is the default skin highlight colors aren't the same as before I revert back to it. What you guys implemented was a green-shaded one, where it was supposed to be blue.
Actually, there is no sound capabilities on power button. But, do you have Stardock Soundpackager installed and apply a sound package? That might be the source of the sound.
No. I don't have that program bought or installed.
It's using the System Notification sound for the Power options in the Start11 menu.
I am not sure what else to recommend. Start11 has no sound capabilities at all. Windowblinds do not apply sound to power button. From what I know, WB only apply sound to Min,Restore,Max and Close buttons. There might be something else is causing that sound.
Have you try this :
or this link: https://www.groovypost.com/howto/manage-system-sounds-on-windows-11/
I went to your suggestion and found out it was the System Notification/Default unassigned sound that's making that sound when I clicked on the Power options.
