left click no work with "Start 11", right click does work.
I just bought START 11 few days ago for my newish Win 11 laptop.  Left clickinging doesnt work most of the time. Right click always works. Sometimes I can change to one of the other 3  "Start Menus" and that fixes the "left click problem, but usually not. Even a reboot wont fix it. So I have to disable it via the"Use the Start 11 Start menu" option. Yes, Im using the "Restart Explorer" button inside "Start 11"
Help!!!
Edition Windows 11 Home
Version 21H2
Installed on ‎5/‎26/‎2022
OS build 22000.832
Experience Windows Feature Experience Pack 1000.22000.832.0
1,269 views 3 replies
Sorry to hear you are having issues. Please try purge and reinstall steps as mention here : [Link]. Just make sure to redownload the latest version from your account page. Reboot after the purge. Reinstall and reboot again after the installation. Retest and report back here.
Working so far, but disabled task bar function. Thanks for help.
