small white rectangle in upper left corner of screen while using Autodesk Inventor
Is any user of Fences aware of this problem, namely a small white rectangle on the upper left corner of my monitor. When I minimize the application, it disappears but comes back after maximizing. Sometimes it disappears and comes back later. I uninstalled Fences but the problem remains. It came up after installing Fences on my new PC. My previous PC had it also.
Thanks for your answer.
4,041 views 1 replies
Sorry to hear you are having issues. I don't have Autodesk Inventor. But would suggest to try the purge and see if it help solve the problem. https://forums.stardock.com/486084/fences-support-faq#reinstalling
Try it and report back.
