help help help
I've been using Rally Points to tag the locations of Pirate bases so that later I can find them and take them out. Now I have a bunch of rally points that I want to delete but can't figure out how to get rid of them. There is no delete option on the menu, nor can you just click on it and press the Delete key.
So how do you delete them?
Also, is there any way to sort the ship list? Both the list in the Shipyard screen as well as the ship tab could REALLY use a sort feature.
10,169 views 1 replies
Click on offending rally point and you should see three buttons "new" "move" & "delete" at the bottom left of  you screen.
Edit:
Assuming you're playing galciv 3
