Problems with Downloading HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
When I try to download many a file from Wincustomize.com (for example a login screen named XPProfessional.logonxp ) I get downloading a file that is named XPProfessional.logonxp.wmz which makes absolutley no sence. Has anyone had this problem??? I am using Mozilla 1.3 to download files and look at this site. >
2,324 views 4 replies
Makes no sence to me
The problem here is that something is attaching another extension to the file name. Try simply deleted the wrong part, in this case .wmz and see if it loads up correctly.
Powered by SkinBrowser!
