How much memory and how fast should it be for my 64 bit system?
Does the speed of my memory really matter?
When upgrading memory remember to look for real evidence of the value of the memory speed and size on the game you want to run.  Maybe Stardock could publish a white paper on the subject related to their products.  And if they demure from recommending a particular brand and model of memory then maybe just the specs they find as the sweet spot.
Linus gives a 5 minute explanation.
http://www.youtube.com/watch?v=dWgzA2C61z4
For those who don't like to watch videos: the sweet spot on price and real game enhancing performance reveals itself at DDR3 1866 CAS 9.  I say "real game" performance because that's where it matters.  The artificial benchmarks that people use in the overclocking community are really only good for the overclocking community.
Remember that this is for today's cpu, motherboard and memory configurations.  Linus was using state of the art I7 4700K in his demonstration.  Two years from now when Gal Civ III is finally released from beta the sweet spot recommendations may have changed.
Newegg.com
Best prices on Sat, Nov 9 2013
$68.99  with Free Shipping
Team Vulcan 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model TLYD38G1866HC11DC01
  • Cas Latency: 11
  • Voltage: 1.5V
  • Multi-channel Kit: Dual Channel Kit
  • Timing: 11-11-11-28
  • Model #: TLYD38G1866HC11DC01
  • Item #: N82E16820313395
  • Return Policy: Memory Standard Return Policy
$149.99   with Free Shipping
+ 15% off w/ promo code EMCWWXR26, ends 11/11 ($127.49)
  • Cas Latency: 9
  • Voltage: 1.5V
  • Timing: 9-10-9-28
  • Model #: F3-1866C9D-16GXM
  • Item #: N82E16820231615
  • Return Policy: Iron Egg Guarantee Return Policy
$294.99  with Free Shipping
  • Cas Latency: 9
  • Voltage: 1.5V
  • Multi-channel Kit: Quad Channel Kit
  • Timing: 9-9-9-27
  • Model #: 994105
  • Item #: N82E16820226387
$749.99  with Free Shipping  (yes - they better give you free shipping when your plunking down $800   ;P )
  • Cas Latency: 9
  • Voltage: 1.5V
  • Timing: 9-10-9-27
  • Model #: CMZ64GX3M8A1866C9
  • Item #: N82E16820233384
May your Civilizations flourish in 64 bit.  It's just too damn exciting and I can't wait.
backs out of the room slowly...  (also looking forward to the Sacrifice of Angels 2 update (Goa and Zombie you too (All you guys rock!(Thanks))) )   *_* :borg:
After thought:  The SOA2 update is out and it was fantastic.
28,333 views 5 replies
As long as my i7 3770K with 8GB of ram (i could crank that up to 16gb) backed up by a 256GB SSD can play galciv3 I'll be happy.
I would hang fire on memory for the moment, there is plenty of time, just see how Stardock is going to put the extra memory to use first, and how they will do it. I suspect Win 7  8Gb will be the new "practical minimum" (they will not force people to buy more than 8Gb to keep up minimum performance levels). Above that will depend on what they ultimately do with it. I suspect 16Gb will be the maximum they will play with on mainstream, any more than that and it forces people to go Win 7 Pro (with its 192Gb max memory)  and they will not do the latter as a compulsion.
There is little doubt they will make it worthwhile getting more than 16Gb, but not "mainstream" as it would force upgrades to Win 7 Pro, the latter's not happening as a mainstream proposition.
I suspect 8Gb will be the sensible minimum, with 16Gb nice to have, and 16Gb + a nice bonus. There is no rush to buy it, it will be a while before even the Beta "needs" the higher quantity of memory. Just "hang loose" for a while, and buy a bargain, but otherwise leave it until mid next year if you are currently on 4Gb. If on 8Gb now, leave it, only buy more if final performance in a year's time dictates it. Just bare in mind that more than 16gb will need Win 7 Pro .....
Also worth buying higher speed memory if shelling out for more anyway, it does have significant benefits over 1600ns  memory, just make sure your maotherboard supports the higher speeds (2133 or 2400ns - higher speed than that is marginal and you pay through the nose for it). Do the homework on memory above 1600ns, not all boards support it, and you need to make sure the specific speed and memory manufacturer is supported by the motherboard.
A nice practical high end (ish) memory as a starter for ten: http://www.overclockers.com/gskill-ripjaws-ddr32133-8gb-ram-review/,
However, generic memory is fine for 95% of people, don't knee jerk high end matched memory unless the motherboard can really use it to the full.
Well clearly you need this game to have better resolutions than real life!  (I just want a ton of races to all murder each other in a truly enormous galaxy).
Overall the 64 bit sounds great, keep the options available for this game to scale across multiple memory sizes.
Quoting Zydor, reply 2
End of Zydor's quote
True if you are doing specialized work like video compression and you're doing it everyday.  My point and the point Linus makes is related to FPS in gaming for the average gamer.  1866 MHz is a sweet spot right now in terms of price and performance.  It's bang for your buck (which is why so many people still prefer AMD CPUs to Intels).  Paying for memory faster than 1866 would mean you have other interests that would benefit from the upgrade.  I don't want to mislead anyone.  But I agree with you about applications like video editing, especially when time is money and everybody wants it yesterday.
backs out of the room slowly...   *_* :borg:
Quoting RedDwarf999, reply 4
End of RedDwarf999's quote
Watch out for the banana skins ..... \o/
