Problems with these skins?!?!
How come when you load a skin, lets say your in internet explorer... why can't you close it by the "X" and minimize by the "-"?? It wont work??
With EVERY skin..
WinXp.
1,962 views 2 replies
Do you have something called CommonNames installed? This has a buggy hook which does not pass on messages to WB correctly. Uninstall it and the problem should go away.
Logitech mice also came with some software that would cause something similar. Not sure if that bug was ever worked around or if that is the name of the software.
