system icons (mypc,recycle bin,drives) wont work please help
hello everyone my system icons dont work anymore.
objectdock was working without a problem,but after and install and uninstall a program called paperport from nuance co, they dont work anymore
when i say system icons i mean ( my pc, recycle bin, folders,drives) the rest of the icons work but not the ones i mentioned before.
i am thinking that when i uninstalled paperport i uninstalled some system drivers but i dont know which ones.
any help will be greatly appreciate it.
i can Launch my pc or recycle bin from the icon on my desktop BUT not from OD.
2,792 views 4 replies
Have you tried removing the problematic icons from the dock and putting them back on?  I don't know for sure but that might do it, maybe just try 1 to see if it works.
thanks for the reply,it does not work i even tried uninstalling OD, but they still dont work.
i am using win 7 64 bit, but as i said they used to work.
thanks
Libby what you can try is using the Sytem Restore function in Windows and restore to a date before you download paperport.  If nothing else is wrong that should clear it up.
EDIT:  Another thing to check is make sure the shortcuts on ObjecDock are showing the correct url link by comparing it to those on shortcuts on your desktop.
thanks everyone for the replies, but unfortunally it did not work, i guess i will have to Launch my system icons from the desktop.
thanks for trying
