Help with windowblinds skin problem.
I was just wondering if there is any way to move where it says (new programs installed) by the all programs bar or button or whatever you call it, anyway where it says new programs installed is kind of to the left, any way to change it?
1,437 views 3 replies
If your talking about a tooltip, where it comes up is in relation to where the cursor is when you mouseover. Other than that I''m not sure what you would mean.
[Message Edited]
"New Programs Installed" should only show up in a tooltip after you have installed new items in the Programs section of the Start menu. It is supposed to disappear again after you have clicked on the item in the More Programs menu. As far as I know, there is no way in WindowBlinds or in Windows XP to control the location of the tooltip.
You can disable the tooltip if you want to keep it from showing up. Right click on the Start Button and click on Properties. It should open on the Start Menu Tab, if not, then click the tab. Click the Customize button on the right. In the new window that pops up, click on the Advanced tab. The first section is for Start Menu Settings. Uncheck the box next to "Highlight Newly Installed Programs." As far as I know, this is the only thing you can do to affect this feature.
Powered by SkinBrowser!
[Message Edited]
Thanks you guys but I didn't think you could move it, but I thought I'd ask anyway. Doesn't seem like it has been that far left before, oh well.
