Problem with weather script in Builder Mode
Hi,
seeking for help here. I have that old object of mine that used to utilize the old weather script. I am very clear about the fact it doesn't work anymore but now I am stuck with not getting access to any object in as the "Invalid Zipcode" dialogue pops up everytime and I have absolutely no chance to get to the scripting of any object as the dialog is in the way and blocks rightclicking the objects.
Is there any trick to start a DX object without the autorun of scripts ? Maybe some secret parameter or key ?
3,913 views 4 replies
I believe if you disconnect from the internet you can make changes as needed. I haven't tried it personally though.
Hm, Good Idea...
The Wiz iz correct. You'll have to rewrite the script.
Yeah, I know, but the thing is I have no chance to get acces to it. Will try to disconnect later.
