Same problem with every theme
Buttons and search bars tiny size!!
Hi there,
I have the same problem with every style that i dowload in WindowsBlinds 6.3
When applying any style the search bar (or any bar) and the buttons font became tiny!! I cant even read what inside
Check the photo to see what i mean
waiting for any solution please :D
17,258 views 19 replies
There was a problem I believe that occured with an update to IE8 and WindowBlinds that was corrected with a WindowBlinds update.
Please open the WindowBlinds Configuration screen and click on System info. Copy/paste that information here.
(Default Monitor) 1 is attached to ATI Mobility Radeon X1600
Wblind.dll      2008/09/17 08:05:20
Wbsrv.dll      2008/09/16 08:44:42
Wbconfig.exe      2008/09/16 08:44:32
Wbload.exe      2008/04/26 16:14:14
Wbhelp.dll      2008/04/26 16:14:07
Wbui.dll      2008/04/26 16:14:05
Tray.dll           2008/04/26 16:14:21
Screen.exe      2008/07/15 11:31:09
Send an email to [email protected] and we'll take care of you.
:maybe:
Same problem but when i write to the support team i get the following:
Hi,
Thank you for your email.
Your email has been filtered and has -NOT- been read due to the following reasons...
1) It matched or contained key items which caused it to be flagged as spam
2) It did not have a subject
3) The body of your email was blank
4) The attachment was a BMP file. To conserve size, please convert it to a JPG or GIF.
5) It contained profanity or abusive language
6) You use a mail filtering/certification system, which requires us to validate our email address
Please restructure your email and resend it so that we may assist you.
Please do not reply to this email.
Stardock Support.
but i just wrote my problem down it's the same than x317's
Help ????
ArsOnist666 -
double post
ArsOnist666
name will probably upset a few email filters.
This problem is there since IE7!
fixed in IE8 and WindowBlinds 6.4, also a workaround is change your setting for "Enable visual styles on buttons and controls in webpages" on the Advanced tab of internet options under Tools on menubar of IE.
(SyncMaster T220/T220G,SyncMaster Magic T220/T220G(Digital)) 1 is attached to NVIDIA GeForce 8800 Ultra
Wblind.dll      2007/09/27 11:40:20
Wbsrv.dll      2009/10/14 03:12:43
Wbconfig.exe      2007/10/01 17:09:33
Wbload.exe      2007/09/27 15:42:44
Wbhelp.dll      2007/07/11 14:06:07
Wbui.dll      2007/09/22 12:13:06
Tray.dll           2007/09/12 17:52:21
Screen.exe      2009/10/14 03:12:24
WindowBlinds 6.0 (build 32 x86)
ArsOnist666
Where did you get this version of WindowBlinds from?
my father gave it to me he bought it ..but don't know when. he does not use it any more because he now has Windows 7.
why is something wrong with it ?
Should i buy a newer version ???
Sorry, no dice.  You can fix it here
Remember: a purchased copy of WindowBlinds is a working copy of WindowBlinds. :thumbsup:
As I said before ... i got it from my father... and i thought it was regular bought by him...so I'll kick his a**
cheerz mate
So, seeing as we went off on this tirade and never addressed the issue, there was a minor update to WindowBlinds 6.4 that addressed and fixes this.  If you have the latest Impulse updates to WindowBlinds 6 or greater you shouldn't see this.  It should also be addressed in MyColors.
