Please fellas,help me,I have a problem with my alien dock,it's like this ^^^^^from 2 days ago.I've uninstalled it 3 times but it is still showing -1% for the CPU,and the hard and RAM,all three don't want to work.That happened after I reboot 2 days ago,and after that it freezed and that's all.I'll be very thankfull to you fellas if you help,I need this program for my job,thank you very much and please help me please,and I'm sorry for my bad English. :)
2,386 views 10 replies
Your English is fine...not to worry.
Is this a Stardock product? Is it a DX app?
Quoting DrJBHL, reply 1
End of DrJBHL's quote
Yes it's an Alienware dock powered by stardock,it go along in set with Alien Xenomorph.Sorry but I don't know what's a ''DX app'' :blush: .I'll be the happiest person on the planet if you help me ^_^ :thumbsup:
P.S. Can you tell me how can I fix it,and start to work properly,thx again ;) Greetings
where did the meters come from?
link to the page would be nice
I believe this is the Invader Dock that comes with AlienGUIse.  This is a Stardock product as it uses OD and My Colors to run, so I would open a ticket with the Stardock support center here.  Hope this helps!   B)
i don't those meters came with aliienguise
They do, becouse I have them also, and only with AlienGUIse.
Fellas the meters came with AlienGUIse skin pack for Windows XP,It will be great if you give me or tell me,other model of meters you know,the thing is I just need CPU meter,RAM meter and eventually hard disk meter,but the first two meters would be just fine if you can give or show me where I can get them,and if they are Stardock product THAT WOULD BE AWESOME,because I think Stardock are the best on the web for this kind of products.
Or if there are no such possibility I will answer every question for you to help me,because I really need them for my job.
CPU meter shows ''-1%'' that happened after reboot,and it just wont go,it freezed.
Here is the place from where I downloaded the ''alien'' dock(it's powered by stardock);):
http://www.alienware.com/community/alienguise/theme-manager.aspx
THANK YOU for the great help and support,I'm really happy that there si people like you,to which I can depend on,sorry for my bad english if there are mistakes,have a wonderful day :thumbsup:
Write to:
support@stardock.com
Tell them the problem.
i stand informed - hadn't run alienguise since it first was available yrs ago
