Multi Connection Problem
OK - this just recently started. I can move the cursor from the 'slave' to the 'master' with no problems. HOWEVER - when I move the cursor from the 'Master' to the 'Slave' the cursor locks on the edge of the 'Master' screen. I have to then move the cursor down to the Windows Taskbar and 'click' the taskbar. The cursor then either appears over on the 'Slave' screen or I can move it into the 'Slave' screen. Movement back to 'Master' goes smoothley - but rinse and repeat when I try to go back to the 'Slave'.
Any ideas? Extremely frustrating as I used to easily move between computers/screens w/o the need to click the 'master' windows taskbar.
tks for any help.
1,538 views 0 replies
