Weather Docklet doesn't work for cities shorter than five characters
Hi all,
I'm a new user to ObectDock and I'm quite satisfied with this utility.
But there's one thing that makes me a bit confused. I cant get weather forecasts for location Brno, Czech Republic. I did some testing and it's seems that the feeder can't get forecasts for cities shorter than 5 characters. E.g. you can get Prague, Olomouc, Berlin, etc but you are not able to get Brno or Zlin.
Can you please fix this bug?
Thx
Vojta
1,049 views 3 replies
Are you using Plus or Free?
In Plus I tested with both cities and OD+ found them.  The free version has not been updated with newer weather code.
Hi,
sorry, I didn't nemtioned I'm using the FREE version. So this might be the problem, right?
How does it look like with updating the free version with newer weather code?
Thx for info!
cheers
Vojta
I don't have an ETA at this time.
