URGENT...stardock softwares making problems..HELP
hi to all!!
well i have 2-3 problems...i have visited millions of forums...but from no where i got proper reply...neither sum proper solution what i must do..
my OS is vista ultimate x86
1.. i m using icon packager 4.0 but it works fine only with icon packages that have been built in.....else icon packges that i download...they r applied..but spceially FOLDER icon gets reverted to default vista icon...sumone told me..it needs vista live feature...but when i click on live folder icon in icon packager...it says buy enhanced version...so i dun hav enhanced...but this must not b so...all users cant hav enhanced version...then wt we do for this prb...
2.. logonstudio vista worked fine for 2-3 times......then it stopped working at all..... i m logged in as administrator...but it dun work...wt i do for it..
3.. i have sum downloaded suites of my colors..but inside my colors there is no option...HOW to load them...they just let u downlaod the suites that u hav bought... any solution for it..
pllzzz help me guys.....m in lots of trouble...
1,831 views 1 replies
Where did you download IconPackager and the MyColors suites? From what I know, you can't actually download MyColors skins. You have to install the MyColors theme manager, and then enter in the serial for the theme you bought from the email you recieve from Stardock. After you do that, the theme will be available to install and apply.
You already received replies in your other thread: https://forums.wincustomize.com/316586/#7
