WindowBlinds and possible AVG 8.0 issue possible solution.
This was my original email to stardock support:
I have had some problems with Windowblinds 6.1.   I had uninstalled it about a month ago. Have tried many times over the last couple of days to uninstall/reinstall it. Each time trying different things like disabling AVG Free 8.0 and through msconfig I have even tried unchecking everything to start windows with a minimum of other programs.
What happens is I install windowblinds from Impulse or SDC it asks me to reboot….I do….then when restarted I go into WB and try to choose the WB Theme Diamond by Stardock I love this theme!!! I either double click on Diamond or hit apply and either the WB window goes away or it starts its thingy and finishes with only the windows classic theme……I keep trying and finally get WBs to load Diamond but then all the windows I try to open are messed up….IE, outlook anything…..the top bar with the maximize/minimize and close buttons are completely gone. I can’t even drag a non full screen window around the screen.
Please help.  I have home premium with SP1 installed, all my drivers are up-to-date, and my system is very clean.
Here is my WB Info:
Your computer has a Windows Experience Index base score of 5
Your Windows Graphics Experience score is 5.9
WindowBlinds version : WindowBlinds 6.1 (build 97 x86 - Vista Edition)
(Generic PnP Monitor) 1 is attached to NVIDIA GeForce 8600 GT
Wblind.dll         2008/05/06 15:25:20
Wbsrv.dll          2008/04/28 11:35:58
Wbconfig.exe               2008/04/29 21:02:32
Wbload.exe     2008/04/28 11:35:14
Wbhelp.dll        2008/04/28 11:35:07
Tray.dll             2008/04/28 11:35:21
Wbload.dll                    2008/04/28 11:34:28
Screen.exe        2008/04/28 11:35:18
I think I may found a solution...at least on my PC....here goes ( from my last email to SD support):
I think I may have solved my problem. The way I got WB to work with AVG 8.0 Free edition is to go to the “resident shield” and add the file locations for all Stardock products to the exception list…….
-----C:\Users\username\Documents\Stardock, C:\Users\Public\Documents, C:\Program Files\Stardock ----
Hopefully this helps others...
My system:
Pentium D 3.2, 2ghz ddr2 ram, Nvidia 8600gt Video, sound blaster live audigy 2 zs platinum, Vista home premium w sp1, hauppauge 250 tuner, sata 3 HDs, all fed to a Vizio 42" LCD...all sound through pioneer 6.1 digital sound system in my living room.....I will never need an office again.
1 step closer to my dream system.
5,629 views 7 replies
Running WB6.1 and the free version of AVG8.0 here and haven't had a problem.
Glad to see you fixed your problem though.
thanks for the post mate it worked like a charm..... :CONGRAT:
Glad I could point you in the right direction. :D
I've just installed AVG 8.0 and was having a complete nightmare - until I saw this thread. Many thanks Alfie414 for an excellent solution  :CONGRAT:
Thanks for this solution, Alfie414, I have just installed AVG 8.0 Antivirus & Firewall & was thinking I would have to revert to AVG 7.5, but your solution has solved the problem, fantastic!
GAWD, I'm just hoping you're running all that audio hardware with an optical tos-link connection for total clarity!
Alfie414,
There are a couple of other issues in AVG 8 Free worth reporting about.
Apparently Grisoft has purchased a program called LinkScanner which causes high CPU utilization. They claim to have fixed the problem, but I recommend not even using it by going to Tools\Advanced Settings\ and on the left chose LinkScanner and uncheck the box on the right.
If you are using HTML e-mail I recommend turning off e-mail certification by going to the same place Tools\Advanced Settings\ selecting e-mail certify on the left and uncheck the box on the right. The certification process messes up your HTML formatting and adds text at the bottom stating it has been scaned by AVG- or something similar. Forgot already. Anyway blatant advertising.
 :D
