Still a Problem with System Tray showing up in Docks
I dont know, I've tried everything..  On the main page it says you can add system tray icons to any dock you have, I can't even do that..  I've tried checking the "Show System tray in dock" option and it still doesn't work.. Anyone have an idea?
2,039 views 6 replies
XP or Vista?
32 or 64?
yes ive read a few posts about this and i have the same problem from what i can gather its vista. iam using 32 bit vista
What version of Object Docka are you running? Are you on the beta? Please try rolling back to the last release version and restarting. Let me know if that clears the issue for you.
Shouldn't have any trouble there. Once you select that setting what happens? Does it go back to the orginal setting? Give you an error message?
DemonicIce:
If you are logging on as a non-administrative limited user, have a look at replies #10 and #13
WWW Link
If you are loggin on with administrative rights as far as I know it should work...
