Please help installation problems
I'm able to successfully download windowblinds but then i get an error message every time i try to launch the setup. It says this is not a valid Win32 application.... I've tried to redownload it but i get the same message every time. Im running windows xp and my computer specs are more than adequate, anyone know what how i can fix this?
1,384 views 3 replies
Are you downloading form Stardock? and if so is it a trial version? Are you using Stardock Central to download it? This is the surest way to make sure it works installs & works correctly.
What is your operating system ?
It's My Secret
Are you using Stardock Central to download it? This is the surest way to make sure it installs & works correctly. Stardcok Central
I wasn't able to edit my original post but I see that you are a current customer so disregard the question about trial version
It's My Secret
not valid could be indicative of a bad download - are you using a download manager?
