Aston shell compatibility problem
I installed both the Aston 1.91 trial and WindowBlinds, using the 5impleAlpha skin supplied. Everything's working well together, except for the start menu, which is experiencing corruption:
http://img24.imageshack.us/my.php?image=10wl1.jpg
http://img24.imageshack.us/my.php?image=23wo.jpg
What could be the source of this problem? Thanks in advance!
2,777 views 6 replies
open WB configure - on the left is system info - click it and copy/paste the info here
WindowBlinds 5.0 System Information Report:
STATUS : WB+ SRV+ HLP+ UI+ TRAY+
WindowBlinds is installed correctly on this PC.
You have one monitor in total.
(Plug and Play Monitor) 1 is attached to NVIDIA GeForce 6800
Wblind.dll 2005/11/28 13:57:10
Wbsrv.dll 2005/12/06 21:16:30
Wbconfig.exe 2005/12/03 03:03:36
Wbload.exe 2005/11/25 19:30:58
Wbhelp.dll 2004/09/18 15:37:00
Wbui.dll 2005/11/20 12:23:40
Tray.dll 2005/11/02 13:28:26
I've also noticed that this problem is only with the 5imple and Windows Classic skins.
Thanks!
is that a WB trial version or paid version?
if its a paid, if you installed through SDC - you might check to see what version is available to you now - i'm running 5.00[b].011 and my dates are more recent on a lot of the dlls
It's the paid version, and nope, I installed it standalone. The only other Stardock program I have is the free version of ObjectDock.
Well, I just switched to the 5imple 4.x substyle, and everything's working well. Looks like it was a skin problem.
Thanks for the help, Bichur!
I could be wrong - but I think you are allowed updates to programs you have purchased, possibly to include betas of WB (not sure on that) - be ever how it may, try downloading SDC if you don't already have it: Link and see if it shows any updated versions available for you - if so, it may take care of the problem
tis possible you may want/need to uninstall wb5 and then reinstall through SDC - there is a place to put your registration code in
