Slight Technical problem: help needed...
Errr, I posted a blog recently and found my blog like this:
If the image doesn't show:
There is a large black bar where my menu on the right should be and below my artivcles. My menu looks as though it is pasted to an article of mine. I tried to check to see if i happened to absent mindedly (don't ask me why i would) put my blog url as the image linke, instead of the specific image intended. But, I can't access the 'edit' option. Or the delete option. Did I cause it?
-Lucas
4,189 views 5 replies
a screenshot of what you are looking at would be better than a link.....
Whoops...thought i clicked the image...sorry.. :S
-EW
Irk! I just put them under image, and the same thing... grrrr
I fixed your blog.  Try not to bork it up again.  If you don't understand how "links" work, please don't use them.  Yes, it was something you did.
*grins sheepishly*
Thanks Karma
-Lucas
