help, themes creation and load problems
I am relatively new to this, I create da desktop with objects, widgets and a wallpaper, I then used theme manager to create a theme file. BUT when the them is attempted to be installed via theme manager when it starts to retrive the skins an error occurs idicating the file is not of the correct format, what am I doing wrong ?
1,281 views 2 replies
What is the specific error message you are receiving? Which theme are you trying to load?
Please do make sure that you have all the necessary components loaded.
-Mike
[Stardock Support]
for desktopx - builder mode - new desktop - create it as you want it - then save the desktop.
or if just modifying - load desktop, go into builder, modify to satisfaction, save (or save as to perserve original)
