Need help with IconPackager and Recycle Bin.
Can somebody tell me why my recycle Bin icons stays the default icon, instead of changing to match the theme of the other icons that I have chosen. My IconPacker is up to date.
4,074 views 5 replies
try restoring to default, rebuild icons and in settings check restore before opening and smart package, see if that helps.
I already tried that. It didn't help.
can you change it manually the 'icons and cursors' option?
sorry... phone was out order for a few days. yes i can change it manually but want it to work correctly with IconPackager.
Ok. I have managed to see that it works ok when Icon X is not running. What is the problem?
