Right Click Problem
I'm currently using the PM2k5 1.1 objectdock.
This theme uses a right click overdrive feature, but in reality I want the original windows right click.
I tried just removing the option from the Floating Bar menu, but it didn't do anything.
Does anyone have a solution? or maybe a recommendation for another theme that is similar to OSX.
Thanks for the help!
1,843 views 2 replies
This is acutally an ObjectBAR theme.
Those who read the thread my have not know how to answer as ObjectBAR and Object DOCK are 2 different programs. You may want to repost to get a repsonse from someone familiar with ObjectBAR. I had no idea what you were talking about so I did a search in the library to find out.
Oh, your title is Right Click problem, and that's applicable except that there's a third program called RightClick. When you repost try something like ObjectBAR Rightclick problem, you'll attract the right people that way.
I'm sorry, your right.
I meant that I'm currently using both objectdock and objectbar. I was using a theme called PM2k5 1.1, but recently switched to Milk v2.
Yet my problem is still there. I want the original right click menu of windows, so how do I turn off the right click features of these themes? Just removing the bar from the properties menu doesn't seem to do it. (maybe I'm doing it wrong?)
If theres no easy solution, does enough recommende a theme that looks similar to either Milk or PM2k5 (prefarably milk, much smoother, although I don't like that plus sign for the system bar)
