HELP!!! Problem after uninstalling WindowBlinds
Taskbar has 2 instances of my windows instead of one...
thanks... but i ended up having to revert the taskbar shell using some tricks online to get it back where it use to be.
2,444 views 2 replies
You need to go into Display properties and switch the visual style from classic to one of the 3 default ones.
Did you return your computer back to default before you uninstalled WB? If not you could try re-installing wb and return the settings to default and then uninstall.
