Problem with my icons... not sure how it happen, but need help fixing.
Not main icons, but rather the tiny folder icons (see pic)
I do not how I lost the icons for the folders in dialog windows ... but I did! Anyone know how to fix these?
Thanks!
Scott
1,916 views 2 replies
This is a weird error you got there. I think reinstalling SDC will fix your stardock central problem. You somehow seem to be missing the ico's in your SDCentral\Images folder?
for the explorer thingy, I have really no idea....
I just noticed that you seem to use 'Enhanced Dialogue'? I would try and unload/unistall/reeboot it and see what happens.....
In light of this, I can't really think of any Stardock proggy that would cause this problem, except of maybe 'Enhanced Dialogue'. So unistalling ED may be the first thing you should try..
if u have iconpackager then u can use the repair icon cache option in it, that would probably fix it...
if u dont hav it, then download the TweakUI powertoy from microsoft site & use the "Rebuild Icons" option in the "Repair" section.
download tweakui from here : Link
hope that helps...
