OD system tray icons problem
don't let me choose "show original icon"
after a clean winXP SP2 reinstall, the option for the icons in the system tray tab to show the original icon in the corner isn't available for clicking anymore... I have OD plus 1.05... any ideas???
screenshot:
4,612 views 3 replies
That feature has been temporarily disabled in OD+. You can edit the 'Settings.ini' located in 'C:\Documents and Settings\username\Local Settings\Application Data\Stardock\ObjectDockPlus'
Add 'EnableTrayMiniIcons=1' to re-enable them.
Doing that may bring back the crashing problem again though......
It may, but I've had no problem with it.
