Ugh! Display Problems on my PC, please help!
from
WinCustomize Forums
g
My guess would be a corrupted graphic driver file, or its registry association.
I just fixed a similar issue on a comp 2 days ago.
Delete the card from the hardware profile and reboot to re-install...if the driver is found and loaded ok then well and good, but in my case the same file was still corrupted and I had to re-install from the backup disk...it was an Acer comp, btw...
