Blur Background does not work with Wallpaper Engine
Blur Background does not work with Wallpaper Engine, but it works when closing Wallpaper Engine, the Windows Wallpaper is the same as Wallpaper Engine, just a static Version of the Wallpaper Engine Wallpaper
And some icons just went blank file I don't know why
And the folder portal does not refresh when a new file is added to the folder, I must refresh the folder portal to make it appear
3,173 views 2 replies
Sorry to hear you are having issues. Yes, it is known that blur don't work if you have Wallpaper Engine running. You just need to turn off blur under Fences configuration->Personalization.
That's sad, if it could just direct the same blur from the Windows Background, it would be Great
Really disabling blur makes the view worse, really like in the folder portal, the text is not clear as with blur
And please inform me of anything to fix the performance and responsiveness issues we discussed before in my first post
Thank you
